Re: Aftermarket Crank angle and tdc sensor??
Quite a regular
I have found myself a e15 dizzy. Numbers on it are... D4p80-08
It has an ignition module in it? Can I pulp that out to fit the mitsi cas? Or is the ignition module important for another function of the dizzy?
Posted on: 2015/2/10 22:54
Subject Poster Date
     Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/7 9:17
       Re: Aftermarket Crank angle and tdc sensor?? Datman95 2015/2/7 9:48
         Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/7 10:24
           Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/7 10:48
       Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/7 18:15
         Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/7 21:19
       Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/8 3:34
         Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/8 4:46
         Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/8 8:16
           Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/8 10:27
           Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/10 22:54
             Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/10 23:19
               Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/11 3:05
       Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/15 5:35
         Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/15 8:00
