Re: Engine plate
It is a matched set:
* plate
* transmission type
* flywheel
* throwout bearing sleeve
If these all came from the donor car you will be alright.
If you mix-n-match, it becomes a problem. For example, all the above from an A14-powered B210 but using an A12 flywheel. In that case better leave off the plate.
Posted on: 2015/2/25 0:37
Subject Poster Date
     Engine plate thegame69 2015/2/24 22:19
       Re: Engine plate ddgonzal 2015/2/24 22:31
         Re: Engine plate thegame69 2015/2/25 0:09
           Re: Engine plate ddgonzal 2015/2/25 0:37
       Re: Engine plate thegame69 2015/2/25 4:42
         Re: Engine plate ddgonzal 2015/2/25 7:45
           Re: Engine plate 1200rallycar 2015/10/11 12:45
             Re: Engine plate ddgonzal 2015/10/11 13:40
               Re: Engine plate 1200rallycar 2015/10/11 23:50
       Re: Engine plate 1200rallycar 2015/10/11 23:56
         Re: Engine plate ddgonzal 2015/10/12 2:45
           Re: Engine plate 1200rallycar 2015/10/17 7:58
