Re: Which brake adapters to use?
I'd be going the s13 upgrade for my money.
S13 uses vented discs but the 280zx doesn't, so there could be a slight weight difference, but if it ever sees some track use, you might see some fade with the solid rotor. You've also got better pad choice with the s13 compared to the sunny/pulsar caliper in the 280zx swap.
Lots of guys on here are using the s13 brake swap, seems to be the best bang for your buck.
Posted on: 2015/3/16 20:00
Subject Poster Date
     Which brake adapters to use? greenspeed 2015/3/16 16:20
       Re: Which brake adapters to use? Flatto 2015/3/16 20:00
       Re: Which brake adapters to use? greenspeed 2015/3/16 22:11
