Browsing this Thread:
1 Anonymous Users
Re: Fuel pressure regulator? |
From sydney
I think you should keep it on depending on what fuel pump you are running . The blow through setup would have run a pump to keep fuel pressure 3-4 psi above boost pressure hence the rising rate reg. So if your have gone back to NA, i'd say you will have too much pressure and have to regulate it back to 3-4 psi.
The fuel pressure reg will never rise as its not under pressure (boost) or you could go back to a standard pump.
Hope this helps
Posted on: 2015/5/27 11:22
Edited by go1200 on 2015/5/27 13:57:17
