Re: Brake pedal random loss of pressue
From Sydney Australia
Master Cylinder seals are toast one from wear and tear the second one likely corrosion from sitting around unused for a while are the only causes of such behaviour.
New Master cylinder or a very close inspection for corrosion and a new seal kit, I would do all the seals at the same time rear brakes as well and make sure the caliper pistons move freely and if not strip and clean and or replace front barke seals as well .
Generally though front calipers do not leak just seize up which means firm pedal and no brakes. so loss of pedal is related to both Rear Brake cylinders and or master cylinder.
Posted on: 2015/6/10 20:12
Subject Poster Date
     Brake pedal random loss of pressue Brevlin 2015/6/10 15:25
       Re: Brake pedal random loss of pressue coxsteve 2015/6/10 20:12
       Re: Brake pedal random loss of pressue JDWhite 2015/6/13 14:21
         Re: Brake pedal random loss of pressue ddgonzal 2015/6/13 22:34
           Re: Brake pedal random loss of pressue levey 2015/6/14 12:30
       Re: Brake pedal random loss of pressue b310gx 2015/6/14 14:17
       Re: Brake pedal random loss of pressue Brevlin 2015/6/24 9:10
       Re: Brake pedal random loss of pressue b310gx 2015/6/24 10:50
         Re: Brake pedal random loss of pressue ddgonzal 2015/6/24 20:15
