Re: Fitting RX7 calipers to 1200/120Y struts
To fit the S4 four pot to Datsun struts is simple:
The spacing for 120Y struts is slightly different from the 810 struts in this photo, but both are much narrower than the RX7 caliper bolt spacing. So a similar bracket can be fabricated. The next questions are 1) how far to space the caliper up and 2) how far to space it out/in (how thick is the adapter). The answer depends on which rotor you use.
Posted on: 2015/12/2 9:23
Subject Poster Date
     Fitting RX7 calipers to 1200/120Y struts ddgonzal 2015/12/2 9:20
       Re: Fitting RX7 calipers to 1200/120Y struts ddgonzal 2015/12/2 9:23
       Re: Fitting RX7 calipers to 1200/120Y struts supafatto 2015/12/2 10:15
         Re: Fitting RX7 calipers to 1200/120Y struts a12grunt 2015/12/2 10:26
         Re: Fitting RX7 calipers to 1200/120Y struts supafatto 2015/12/2 10:36
           Re: Fitting RX7 calipers to 1200/120Y struts a12grunt 2015/12/2 10:41
             Re: Fitting RX7 calipers to 1200/120Y struts ddgonzal 2015/12/3 1:39
               Re: Fitting RX7 calipers to 1200/120Y struts ddgonzal 2015/12/3 2:05
                 Re: Fitting RX7 calipers to 1200/120Y struts ddgonzal 2015/12/3 7:44
                   Re: Fitting RX7 calipers to 1200/120Y struts a12grunt 2015/12/24 6:59
       Re: Fitting RX7 calipers to 1200/120Y struts datman 2016/1/5 18:55
         Re: Fitting RX7 calipers to 1200/120Y struts ddgonzal 2016/1/5 21:06
       Re: Fitting RX7 calipers to 1200/120Y struts datman 2016/1/6 6:54
         Re: Fitting RX7 calipers to 1200/120Y struts ddgonzal 2016/1/6 8:36
