Re: Valve to piston clearance
Something to consider there pointed by Neil is the rocker geometry in case you change to roller rockers or similar higher ratio rocker, cam or other in the future. Doing it now leaves some scope for the future and safety margin.
Depending on the compression you can just mill them 1.5mm etc but notching for valves is not expensive.
Posted on: 2015/12/10 12:17
Subject Poster Date
     Valve to piston clearance thaifrog 2015/12/9 15:09
       Re: Valve to piston clearance ddgonzal 2015/12/9 22:47
       Re: Valve to piston clearance thaifrog 2015/12/10 2:53
       Re: Valve to piston clearance D 2015/12/10 3:30
         Re: Valve to piston clearance ddgonzal 2015/12/10 3:55
       Re: Valve to piston clearance D 2015/12/10 3:59
       Re: Valve to piston clearance thaifrog 2015/12/10 9:30
       Re: Valve to piston clearance thaifrog 2015/12/10 9:57
       Re: Valve to piston clearance dattoman_1000 2015/12/10 10:52
         Re: Valve to piston clearance nzdatman 2015/12/12 8:56
       Re: Valve to piston clearance D 2015/12/10 12:15
       Re: Valve to piston clearance D 2015/12/10 12:17
       Re: Valve to piston clearance thaifrog 2015/12/10 13:33
       Re: Valve to piston clearance thaifrog 2015/12/12 10:12
       Re: Valve to piston clearance Dundee1000 2015/12/14 9:03
         Re: Valve to piston clearance dattoman_1000 2015/12/14 10:22
       Re: Valve to piston clearance nzdatman 2015/12/16 8:16
       Re: Valve to piston clearance thaifrog 2015/12/16 10:10
         Re: Valve to piston clearance dattoman_1000 2015/12/16 13:15
