Re: Coil over kits for 120Y ?
92 lbs/in is a great rate for comfort and control. Use a high quality strut shock valved for the 1200 -- like the Nissan unit available from Bprojects or new-datsun-parts
If you have lowered the ute, then you'll want a higher rate spring so that it won't bottom out so easily. If you have lowered the ute 3" then you'll probably want 250 lbs/in
Posted on: 2015/12/14 12:20
Subject Poster Date
     Coil over kits for 120Y ? Anth94 2015/12/14 9:02
       Re: Coil over kits for 120Y ? supafatto 2015/12/14 9:45
       Re: Coil over kits for 120Y ? ddgonzal 2015/12/14 9:56
       Re: Coil over kits for 120Y ? mr_dat 2015/12/14 10:31
         Re: Coil over kits for 120Y ? ddgonzal 2015/12/14 12:20
       Re: Coil over kits for 120Y ? Anth94 2015/12/15 9:19
         Re: Coil over kits for 120Y ? ddgonzal 2015/12/15 9:24
       Re: Coil over kits for 120Y ? Anth94 2015/12/15 9:38
         Re: Coil over kits for 120Y ? supafatto 2015/12/15 9:57
           Re: Coil over kits for 120Y ? zigmondo 2015/12/15 21:17
             Re: Coil over kits for 120Y ? Brevlin 2015/12/16 9:45
               Re: Coil over kits for 120Y ? zigmondo 2015/12/16 11:26
