Re: Trigger wheel mount to space in double pulley
You could have a machinist make a trigger ring to the dimensions you want.
The photos above use the USA-spec 1990-1993 Escort ring, which is a press fit on the original Ford car. Only $5 at a wrecking yard or $20 from eBay. At 144 mm, it's the right diameter for the 139mm A12/A14 pulley, and might work for you if machined down to 1/8" thick. This wheel is about 102-103 mm inside diameter.
jpg  edis_escort.jpg (41.34 KB)
174_568c53b47dda6.jpg 322X272 px
Posted on: 2016/1/5 23:37
Subject Poster Date
     Trigger wheel mount to space in double pulley thomen 2016/1/5 21:56
       Re: Trigger wheel mount to space in double pulley lamb_daiquiri 2016/1/5 23:07
         Re: Trigger wheel mount to space in double pulley thomen 2016/1/5 23:32
           Re: Trigger wheel mount to space in double pulley ddgonzal 2016/1/6 0:04
             Re: Trigger wheel mount to space in double pulley thomen 2016/1/6 0:33
               Re: Trigger wheel mount to space in double pulley ddgonzal 2016/1/6 0:46
                 Re: Trigger wheel mount to space in double pulley ddgonzal 2016/1/6 1:00
       Re: Trigger wheel mount to space in double pulley ddgonzal 2016/1/5 23:12
         Re: Trigger wheel mount to space in double pulley ddgonzal 2016/1/5 23:23
           Re: Trigger wheel mount to space in double pulley ddgonzal 2016/1/5 23:37
       Re: Trigger wheel mount in Flywheel ddgonzal 2016/1/6 0:22
