Re: Calculating compression ratio
From Fort Worth, Texas
Ok guys. I got a more accurate syringe at a feed store and its in ml which is equivalent to cc. Measured it several times. GX head is 28 ml/cc and the piston dish is 13 ml/cc. Can someone run the numbers for me? I really prefer not to use premium gas if I dont have to. But DD makes an interesting point that if I have higher compression it will get better fuel economy which makes it a wash.
You guys may notice I am a novice at all this but slowly picking up alot along the way and will be better prepared for my next build. I have worked on a variety of automobiles for many years but not with the technical components (cam lift/duration, compression etc) of an internal combustion engine. You all must be engineers.......
Posted on: 2016/1/15 17:35
Subject Poster Date
     Calculating compression ratio TexasMidget 2016/1/10 6:37
       Re: Calculating compression ratio ddgonzal 2016/1/10 6:54
       Re: Calculating compression ratio lamb_daiquiri 2016/1/10 8:21
         Re: Calculating compression ratio ddgonzal 2016/1/10 9:10
       Re: Calculating compression ratio TexasMidget 2016/1/10 15:57
         Re: Calculating compression ratio dvr1000 2016/1/11 1:46
       Re: Calculating compression ratio thaifrog 2016/1/11 5:38
       Re: Calculating compression ratio TexasMidget 2016/1/11 5:56
         Re: Calculating compression ratio ddgonzal 2016/1/11 6:33
           Re: Calculating compression ratio TexasMidget 2016/1/11 15:29
             Re: Calculating compression ratio ddgonzal 2016/1/11 23:37
               Re: Calculating compression ratio ddgonzal 2016/1/11 23:50
       Re: Calculating compression ratio TexasMidget 2016/1/15 17:35
       Re: Calculating compression ratio Rallytwit 2016/1/16 4:59
       Re: Calculating compression ratio TexasMidget 2016/1/16 5:31
         Re: Calculating compression ratio ddgonzal 2016/1/16 6:42
           Re: Calculating compression ratio TexasMidget 2016/6/22 4:22
             Re: Calculating compression ratio ddgonzal 2016/6/22 4:36
               Re: Calculating compression ratio ddgonzal 2016/6/22 4:42
                 Re: Calculating compression ratio TexasMidget 2016/6/22 4:50
       Re: Calculating compression ratio Rallytwit 2016/6/22 4:37
