Re: Alternator i brought from auto8 need wiring switched
The T-wiring will not be used on the Bosch alternator. It doesn't use those wires. There is no Field wire, because the field wire comes from the Regulator and the Bosch is internally regulated. The other T-wire for the FN type alternator is the Neutral Point. This also is for the regulator. So neither of those wires are used with internally-regulated alternators
Posted on: 2016/1/28 5:48
Subject Poster Date
     Alternator i brought from auto8 need wiring switched datsunny79 2016/1/27 7:48
       Re: Alternator i brought from auto8 need wiring switched ddgonzal 2016/1/27 8:44
         Re: Alternator i brought from auto8 need wiring switched ddgonzal 2016/1/27 10:17
       Re: Alternator i brought from auto8 need wiring switched datsunny79 2016/1/28 4:24
         Re: Alternator i brought from auto8 need wiring switched ddgonzal 2016/1/28 5:48
           Re: Alternator i brought from auto8 need wiring switched ddgonzal 2016/1/28 5:59
             Re: Alternator i brought from auto8 need wiring switched datsunny79 2016/1/29 5:15
               Re: Alternator i brought from auto8 need wiring switched ddgonzal 2016/1/29 7:20
