Browsing this Thread:
1 Anonymous Users
A14 turbo Electronic fuel pump help? |
From Canberra
Hey guys i have setup an A14 turbo setup into a mates 1200 sedan with a t28 turbo with intercooler into a 32/26 weber it runs quite alright but its completely dying off when getting into the higher rpm now its currently on the stock mechanical pump which is more of the concern with the fuel regulator showing around 3.4 psi which is just too low for the turbo setup
Now i have a bosch 44 electronic fuel pump i can throw inline but my question is will i need to put in a raising fuel rate regulator or just run it through to the carb on the exisiting fuel pressure regulator and just adjust it on that regulator?
And if i do need a raising fuel rate regulator will i need to setup a surge tank with return line back into the tank?
Posted on: 2016/2/29 0:50
