Re: {HELP} Illumination lights for dash cluster
want to confirm for the dimmer wire separate from the instrument panel wiring, where should it be connected to?? is it earthed to the dash?
Yes, the dim/bright (AUS) wire is connected to the instrument panel. It is the LG (Blue with Green stripe) at the switch, so make sure there is voltage there
At the actual instrument panel, it may be a different color (GL) and is pin 4
And remember they won't work until the cluster is bolted to the dash. The oil, alt, beam lights may work, but the illumination lights won't work until it is earthed
Posted on: 2016/4/27 21:45
Subject Poster Date
     {HELP} Illumination lights for dash cluster loosekid 2016/4/27 12:02
       Re: {HELP} Illumination lights for dash cluster coxsteve 2016/4/27 20:07
         Re: {HELP} Illumination lights for dash cluster ddgonzal 2016/4/27 21:45
           Re: {HELP} Illumination lights for dash cluster loosekid 2016/4/28 2:25
             Re: {HELP} Illumination lights for dash cluster ddgonzal 2016/4/28 5:59
               Re: {HELP} Illumination lights for dash cluster ddgonzal 2016/4/28 6:19
