Re: A15 twin weber electric dizy valve bouncing at 4500rpm??
Not too shy to talk
From Brisbane
Hi RockOn, im sure it not the clutch set up, because all the issues i was having with it in that respect are gone, dont get me wrong, it was a major headache and i was certain that it was limiting the engine some how but its not.. at least now it shifts smooth as silk haha
i did free rev it all the way out once but the problem sort of comes and goes, especially if i leave it in gear from low rpm and drive it through the rev range (worst in 3rd)
cheers ddgonzal, ill have a check of the dizzy when i get some time and daylight, is it worth marking the outside of the cap to the body so i don't put it back on crooked?
once ive got all this fixed i think im going to look into upgrading the whole ignition system, ive heard putting the work into the spark side helps a lot on dead cold starts also
Posted on: 2016/7/12 1:29
Subject Poster Date
     A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/6/29 0:39
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/6/29 2:27
         Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/6/29 4:42
           Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/6/29 5:18
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? Rallytwit 2016/6/29 5:54
         Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/6/29 7:28
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/6/30 0:39
         Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/6/30 1:16
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/6/30 1:26
         Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/6/30 1:55
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/7/11 2:30
         Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/7/11 9:22
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? RockOn 2016/7/11 15:10
         Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/7/11 20:08
           Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/7/12 1:29
             Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/7/12 1:59
               Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/7/12 3:00
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/7/13 2:53
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? lamb_daiquiri 2016/7/13 2:56
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/7/13 3:02
         Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/7/13 3:57
           Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/7/13 4:13
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? Rallytwit 2016/7/13 5:32
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/7/14 3:16
         Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? ddgonzal 2016/7/14 3:44
       Re: A15 twin weber electric dizy valve bouncing at 4500rpm?? jzande 2016/7/18 5:49
