Re: Wheel spacer and Hub bolts
From Mordialloc Victoria 3195
I had the same problem so I decided to mount the strut tops on top of the tower using a machined top plate to clear the ridge and a bottom plate to reinforce/support on the under side.
This dropped the car about 30mm so I could lift the coilover adjustment up to clear the tyre without spacers
( allowing the tyre full clearance up into the wheel arch without scraping )
LOW IS GOOD
jpg  P1010014.JPG (158.17 KB)
16236_58eaeb54673d6.jpg 640X480 px
Posted on: 2017/4/10 3:18
keep it simple
Subject Poster Date
     Wheel spacer and Hub bolts dhadina 2017/4/9 7:02
       Re: Wheel spacer and Hub bolts dhadina 2017/4/9 7:23
         Re: Wheel spacer and Hub bolts ddgonzal 2017/4/9 18:52
           Re: Wheel spacer and Hub bolts zigmondo 2017/4/10 3:18
       Re: Wheel spacer and Hub bolts dhadina 2017/4/10 6:34
         Re: Wheel spacer and Hub bolts zigmondo 2017/4/10 8:15
         Re: Wheel spacer and Hub bolts dhadina 2017/4/10 11:23
           Re: Wheel spacer and Hub bolts dhadina 2017/4/10 11:31
             Re: Wheel spacer and Hub bolts zigmondo 2017/4/11 4:16
