$265.00USD Nissan 350z Coilovers You Must Like
Not too shy to talk
Fit for: Nissan Coilover Fairlady Z 350Z Z33 / Infiniti G 35
Quantity: -2 front+2 rear shocks -C- Spanner for adjustment -Front Bump stops and dust covers
Warranty: 1 year warranty
Features:
1.Adjustable ride height
2.Adjustable pre-load spring tension
3.Most components are made from 6063 aluminum with T6 for increased hardness -- the advantages include excellent strength, and aluminum helps keep the weight down.
4.Hi Tensile performance spring - Under 600,000 times continuously test, the spring distortion is less than 0.04%. Plus, the special surface treatment is to improve the durability and performance.
5.All inserts come with fitted rubber boots to protect the damper and keep clean.
6.Improve your handling performance without sacrifice comfortable ride.
7.A fast and affordable way to easily upgrade your car's appearance.
8.Easy installation with right tools.
9.Ideal for any track, drift and fast road and can also be used for daily driving.
Click: http://www.maxpeedingrods.com/Coilovers-Spring-for-Nissan-0350Z Z33-Fairlady-Z-02-09-Shock-Absorber.html
Posted on: 2017/6/22 3:58
Subject Poster Date
     $265.00USD Nissan 350z Coilovers You Must Like Wendmiler 2017/6/22 3:58
       Re: $265.00USD Nissan 350z Coilovers You Must Like mr_dat 2017/6/23 11:49
