Re: Miata crank in A-series block?
Just a pointer on the E16 crank is I could be wrong but
the snout is smaller so will need a sleeve to fit the
A series timing pulley but can be overcome using the
Mazda kit as the Z series head has smaller belt pulleys
with slightly smaller diameter than A series.
The Z series head is like a narrow valved modern bike
head with 22 or 23 degree valve angles and awakened
when using different camshafts than factory econo ones.
https://www.miataturbo.net/attachments ... 2.jpg?dateline=1326189600
https://www.miataturbo.net/build-threa ... zm-de-engine-build-62722/
Posted on: 2017/12/1 0:23
Edited by D on 2017/12/1 2:41:31
Edited by D on 2017/12/1 2:45:49
Subject Poster Date
     Miata crank in A-series block? Rallytwit 2017/11/30 6:46
       Re: Miata crank in A-series block? D 2017/11/30 13:04
       Re: Miata crank in A-series block? D 2017/12/1 0:23
