Browsing this Thread:
1 Anonymous Users
60A 5 speed question |
From Seattle ,WA.
I have a leak coming from the transmission into the "Striking guide" assembly, its the cast steel shift selector piece that the shift control lever goes into.
It has oil pooling in the hole that the nylon bottom of the shift lever fits into, there are 2 seals, an O ring on the "guide" shaft thats between the guide & trans housing then the book says theres one in the end of the striking guide under a steel plug. Im sure I never replaced that one, does that one keep the fluid from the trans separate from the guide?
Anyone ever take one of these ends completely apart?
thanks
Posted on: 2018/6/1 16:45
