SR20VE versus 3SGE
Just a comparo but missing information if anyone can fill in the gaps?
Its interesting as the 3Sge is very plentiful in comparison to the VE
SR20VE
207PS 205 PS / 152 kW @ 7200 rpm
152 lbs ft / 206 nm @ 5200
Capacity 1,998 cc (2.0 L)
Bore x Stroke 86 mm x 86 mm
Variable Performance Mechanism Dual VVL?
Compression Ratio XX.?
Valve Material Steel-Alloy: ?
Intake Valve Diameter 30 mm
Exhaust Valve Diameter 34 mm
Included Valve Angle ?°
Conrod length: 136.3mm
Weight:
later versions more hp had 70 mm throttle body (earlier 60 mm)
Block Height: 211.3mm
Crankshaft journal diameter: 55.0mm
Crankpin diameter: 48.0mm
Versus
3S-GE gen 5
210PS 207hp / 154 kW @ 7,600 rpm
22.0 kg⋅m (216 N⋅m) at 6,400 rpm.
Gen 5 Capacity 1,998 cc (2.0 L)
Bore x Stroke 86 mm (3.39 in) x 86 mm
Variable Performance Mechanism Dual VVT-i
Compression Ratio 11.5:1
Conrod length 137.8mm
Valve Material Steel-Alloy: Titanium
Intake Valve Diameter 35 mm
Exhaust Valve Diameter 29.5 mm
Included Valve Angle 22.5 °
Weight: The 3S-GELU was143 kg (315 lb) fully dressed (later Gen5 was lighter again)
Throttle body or bodies sizes no idea?
Posted on: 2018/10/11 10:15
Edited by D on 2018/10/11 10:42:02
Subject Poster Date
     SR20VE versus 3SGE D 2018/10/11 10:15
       Re: SR20VE versus 3SGE nickmitty 2018/10/11 15:30
         Re: SR20VE versus 3SGE ddgonzal 2018/10/12 0:38
       Re: SR20VE versus 3SGE D 2018/10/12 4:43
       Re: SR20VE versus 3SGE nickmitty 2018/10/12 11:02
         Re: SR20VE versus 3SGE Mattndew76 2018/10/12 14:51
       Re: SR20VE versus 3SGE D 2018/10/15 2:12
       Re: SR20VE versus 3SGE nickmitty 2018/10/15 4:05
         Re: SR20VE versus 3SGE ddgonzal 2018/10/15 11:02
           Re: SR20VE versus 3SGE D 2018/10/16 6:19
             Re: SR20VE versus 3SGE ddgonzal 2018/10/16 8:09
       Re: SR20VE versus 3SGE D 2018/10/16 8:59
       Re: SR20VE versus 3SGE D 2018/10/16 14:56
