A15 crank wil NOT fit in A12 block
From Las Vegas USA
So as clearly I was bored yesterday I tried an A15 crank in an A12 block and there are issues.
First the block in question was a 73.75mm bore. My intent was to use 75mm Honda Pistons in my A12A block
I used the standard A12 rod and piston (knowing th piston was going to stick up 2.5mm), the connecting rod fouls the bore. I didn't measure but the top of the rod bolt contacts the bore so I'd say it needs at least 5mm more clearance.
Next I pulled the rod and piston off the crank; the crank throw contacts the block about a 1/3 of the way along the surface of the throw.
So a couple of things; an A14 crank may fit without these issues given the shorter stroke, the A15 crank might clear the A12A 75mm bore block but I doubt it so I won't be trying it.
Posted on: 2019/9/8 17:24
Subject Poster Date
     A15 crank wil NOT fit in A12 block Rallytwit 2019/9/8 17:24
       Re: A15 crank wil NOT fit in A12 block ddgonzal 2019/9/8 23:20
         Re: A15 crank wil NOT fit in A12 block D 2019/9/9 10:27
           Re: A15 crank wil NOT fit in A12 block ddgonzal 2019/9/9 11:07
             Re: A15 crank wil NOT fit in A12 block D 2019/9/9 14:07
               Re: A15 crank wil NOT fit in A12 block nickmitty 2019/9/9 14:40
       Re: A15 crank wil NOT fit in A12 block dattoboy_nz 2019/9/9 19:45
       Re: A15 crank wil NOT fit in A12 block Rallytwit 2019/9/9 21:00
         Re: A15 crank wil NOT fit in A12 block D 2019/9/10 6:07
       Re: A15 crank wil NOT fit in A12 block dattoboy_nz 2019/9/10 19:59
       Re: A15 crank wil NOT fit in A12 block dattoboy_nz 2019/9/10 20:03
       Re: A15 crank wil NOT fit in A12 block dattoboy_nz 2019/9/10 20:04
       Re: A15 crank wil NOT fit in A12 block Rallytwit 2019/9/11 2:57
       Re: A15 crank wil NOT fit in A12 block dattoboy_nz 2019/9/11 21:01
         Re: A15 crank wil NOT fit in A12 block D 2019/9/13 7:39
       Re: A15 crank wil NOT fit in A12 block dattoboy_nz 2019/9/16 0:07
       Re: A15 crank wil NOT fit in A12 block D 2019/9/16 8:42
