Re: Trying to establish timing
easy pulley nut removal:
* attach breaker bar, rotate clockwise until the bar stops on the chassis rail
* remove coil wire from distributor cap
* turn key to Start (briefly)
This will loosen the nut
When you go to tighten the nut, put the car in 4th gear, block the wheels, set the handbrake, and use a torque wrench. Torque: 15-16 kg/m (108-116 ft. lb.)
Posted on: 2021/8/3 12:25
Subject Poster Date
     Trying to establish timing smellsofbikes 2021/7/30 1:30
       Re: Trying to establish timing ddgonzal 2021/7/30 11:16
         Re: Trying to establish timing ddgonzal 2021/7/30 11:46
           Re: Trying to establish timing ddgonzal 2021/7/30 12:08
       Re: Trying to establish timing smellsofbikes 2021/7/31 20:17
         Re: Trying to establish timing ddgonzal 2021/8/3 12:25
           Re: Trying to establish timing smellsofbikes 2021/8/18 4:54
             Re: Trying to establish timing ddgonzal 2021/8/18 7:43
               Re: Trying to establish timing smellsofbikes 2021/8/21 5:29
                 Re: Trying to establish timing smellsofbikes 2021/8/21 5:32
                   Re: Trying to establish timing ddgonzal 2021/8/21 23:54
