Re: Thanks ddgonzal for the tip!!
From santa maria,ca
hi wildthing, just a note on your oil fouled plugs...it's gotta be either a bad oil ring on the piston, or bad valve stem oil seals. One way to check is to get that compression tester and do a dry reading on all cylinders and record the results. Then squirt some oil into each cylinder and take a second set of readings. If the readings are higher, ya need new rings. Either way, you'll probably have to rebuild the head or the bottom end. Hope this helps.
Roughneck
Posted on: 2003/2/24 22:15
I'll get new tires next week...
Subject Poster Date
     Thanks ddgonzal for the tip!! wildthing 2003/2/23 15:01
       Re: Thanks ddgonzal for the tip!! ddgonzal 2003/2/23 20:38
         Re: Thanks ddgonzal for the tip!! ddgonzal 2003/2/24 8:48
           Re: Thanks ddgonzal for the tip!! wildthing 2003/2/24 14:37
             Re: Thanks ddgonzal for the tip!! roughneck 2003/2/24 22:15
