Re: Roll cage for 3J < 2 litre
From sydney australia
ok,i suppose the best people to talk to are some scrutineers for the series,or someone like john taylor at pedders penrith,whose prepared cars for improved production,or get a referal from the cams office.ask what materials you need tomake the cage from,what mounting points,what sort of welding,what grade bolts,pick thier brains to death.don't use water pipe,cause the first thing they do to a new cage is check to see what it's made of.use a cross brace,it stops the main hoop collapsing.also,spring the money for a new cams manual,it's got a whole section on cages,showing you what they want.i know i've heard that rollcages have to be made by cams certified people,but if you can match the cams standards,you might be able to do it yourself. p.s. i now fro said he was with the nsw road racing club,maybe he can help.
Posted on: 2003/3/3 0:34
Subject Poster Date
     Roll cage for 3J < 2 litre converted 2003/3/1 1:26
       Re: Roll cage for 3J < 2 litre converted 2003/3/1 1:26
         Re: Roll cage for 3J < 2 litre ca18det_man 2003/3/2 5:22
           Re: Roll cage for 3J < 2 litre 1200rallycar 2003/3/2 10:47
             Re: Roll cage for 3J < 2 litre b310gx 2003/3/3 0:34
               Re: Roll cage for 3J < 2 litre L18_B110 2003/3/3 1:44
                 Re: Roll cage for 3J < 2 litre stirlingmac 2003/3/3 2:24
                   Re: Roll cage for 3J < 2 litre L18_B110 2003/3/3 2:39
                     Re: Roll cage for 3J < 2 litre converted 2003/3/3 5:17
