Re: unusual turbo topic, L18 B110 help u seem to know a lot
From Brisbane, Australia
Harry you beat me to it. I was just writing a reply. I'll edit out my bit on oil lines and water lines. :)
If you are using a draw thru setup (the easiest) you will not need an electric fuel pump and will not be able to use an intercooler or BOV (Bloody Obnoxious Valve).
If you decide a blow thru setup is the go you are looking at a little more hassle and money. Firstly you will need to seal off the carby so that the boost cannot leak out. Then you will need to correctly jet the carby. Also your fuel supply will need to be updated with an electronic pump and a rising rate fuel pressure regulator. If you can get all of this to work with great success then you can think about using intercoolers and BOVs.
These item will only work on blow thru setups. Can you imagine running fuel through your intercooler or venting it ou your BOV? Besides a BOV would be pointless on a Draw thru because the throttle is mounted before the turbo. Therefore the turbo does not experience any back pressure when the throttle snaps shut.
Craig
Posted on: 2003/3/28 5:34
Subject Poster Date
     unusual turbo topic, L18 B110 help u seem to know a lot simmodat1200 2003/3/28 4:54
       Re: unusual turbo topic, L18 B110 help u seem to know a lot L18_B110 2003/3/28 5:28
       Re: unusual turbo topic, L18 B110 help u seem to know a lot NoPsi 2003/3/28 5:34
         Re: unusual turbo topic, L18 B110 help u seem to know a lot YRL05S 2003/3/28 5:43
         Re: unusual turbo topic, L18 B110 help u seem to know a lot Lobster 2003/3/28 6:06
           Re: unusual turbo topic, L18 B110 help u seem to know a lot Dragongoose 2003/3/28 16:43
           Re: unusual turbo topic, L18 B110 help u seem to know a lot NoPsi 2003/3/29 13:28
       Re: unusual turbo topic, L18 B110 help u seem to know a lot barpk 2003/3/28 20:08
