Browsing this Thread:
1 Anonymous Users
Re: engine cranking problem.....HELP!!! |
Registered Users Contentmaster Usermaster
As feral and wally implied, the "starter relay" is in the soleonoid attached to the starter. 1200s do not have a separate relay a la Ford style. The relay might be bad, or the spring inside might be broken,
For Chevrolet engines, if the starter-to-flywheel gear spacing is bad, this can also happen (that's what those GM shims are for) ... although unless your starter housing has been machined or doesn't fit right, it's unlikely this would happen to an A-series starter.
Posted on: 2003/4/5 22:44
