Re: fitting 15s on front of 120y...need advice
From Brisbane, Australia
go with the stanza struts and brakes. Not only will you be able to run your 15s without the illegal spacers, but you will also make your car handle and stop better too. there's 3 good reasons.
There's plenty of discussions here about the conversion, and it really all bolts in - not much messing around at all. The only question mark for the 120Y is wether the Stanza castor rod needs to be modified to get the castor 'correct'.
Posted on: 2003/4/22 2:03
Subject Poster Date
     fitting 15s on front of 120y...need advice why120y 2003/4/20 3:24
       Re: fitting 15s on front of 120y...need advice jaimecidpedro 2003/4/20 7:37
         Re: fitting 15s on front of 120y...need advice mely 2003/4/20 9:03
           Re: fitting 15s on front of 120y...need advice L18_B110 2003/4/22 2:03
             Re: fitting 15s on front of 120y...need advice smurf 2003/4/23 13:42
               Re: fitting 15s on front of 120y...need advice 1200rallycar 2003/4/26 13:19
