Re: L18/L20 in 1200
From Invercargill, New Zealand
Hi Simon - here's some info about a L18 that someone put in their 1200. I reckon there are better choices out there now but maybe this will help you make up your mind. This is from Martin
Pots Website at http://members.iinet.net.au/~mpot/DatsunMods/
... has heard of someone who installed an L18 engine into a 1200. Then entire job was done by an
apprentice mechanic. It was a huge job, and involved deeply scalloping the crossmember, engine mount mods, and reshaping the sump.
The engine runs custom extractors for clearance, with a 2.5" system and 3" tip. Induction is twin 45 side draught Webers, which give an incredible throaty roar under acceleration. The
head was extensively worked, with maximum porting, valve increases and a huge cam.
A factory EFI setup imported from Japan was tried, and found to be much smoother, but too restrictive above 6000rpm when used with the cam. The gearbox used is a reverse H Japanese race
box. The radiator is a custom 5 core with a big thermo fan. The diff is a shortened 1200 ute diff.
The engine produced in excess of 170 hp, and was incredibly quick!
Posted on: 2000/5/16 4:19
Subject Poster Date
     L18/L20 in 1200 mr_nismo4 2000/5/16 2:46
       Re: L18/L20 in 1200 Davo1200 2000/5/16 4:18
       Re: L18/L20 in 1200 teretonga 2000/5/16 4:19
         Re: L18/L20 in 1200 ca18det_man 2000/5/16 5:49
       Re: L18/L20 in 1200 stirlingmac 2000/5/16 5:31
         Re: L18/L20 in 1200 leosnake_2000 2000/5/17 6:55
           Re: 1700cc A Series. stirlingmac 2000/5/17 7:28
             Re: 1700cc A Series. leosnake_2000 2000/5/17 7:48
               Re: 1700cc A Series. ca18det_man 2000/5/17 10:45
