Browsing this Thread:
1 Anonymous Users
Re: camshaft specs?!? |
Registered Users Contentmaster Usermaster
This is the range of the A12 stock cam though a more modern grind with more lift should help you get more airflow -- you've already got the ports for high-rpm flow.
Hopefully your double-springs will let you rev close to 7000 rpm (the stock A12 GX double spring were good to 6600). You should be able do it now. A new cam won't let you rev any higher, but should help with a little more power higher up.
Posted on: 2003/6/26 2:21
