vacuum brake boosters under boost
From adelaide
just wondering if anyone has ever used forced induction on a car that has a vacuum brake booster (servo assisted brakes) fitted to it. Where does the line from the intake manifold under the throtle blades (in downdraught carb) to the brake booster go in a forced induction layout. Would it still work if i put it at the inlet of the turbo, would it get any vacuum, or do they remain unaffected by boost pressure and just work as normal non assisted brakes. Any info or advice would be greatly appreciated. thanks guys
Ps: the cars a datto 180b
Posted on: 2003/7/3 11:27
Subject Poster Date
     vacuum brake boosters under boost sikdatto1200 2003/7/3 11:27
       Re: vacuum brake boosters under boost dattodude 2003/7/3 13:37
       Re: vacuum brake boosters under boost datsik 2003/7/3 15:49
         Re: vacuum brake boosters under boost MadTimo 2003/7/3 15:54
           Re: vacuum brake boosters under boost Demojob 2003/7/3 16:13
             Re: vacuum brake boosters under boost dattodude 2003/7/4 1:13
               Re: vacuum brake boosters under boost sikdatto1200 2003/7/4 8:48
