Re: PCV valve on an A12GX - failure anyone??
From Hobart, Tas. Australia
It did have flat top twin carbs on it but they were knackered so we've started with a twin 1 1/2" SU conversion (really similar carbs).
Both butterflies are closing the same amount. The rear carb has it's piston way higher than the front one and is definitely flowing more air.
I intend to keep the pcv valve if I can find a replacement.
I wonder if there could be a leak between inlet and exhaust somewhere on the manifolds.
Posted on: 2003/7/16 23:03
SPITSUN - A12GX powered Triumph Spitfire
View my spitfire on Triumphowners.com
Subject Poster Date
     PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/16 4:48
       Re: PCV valve on an A12GX - failure anyone?? lsd 2003/7/16 4:54
         Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/16 5:01
           Re: PCV valve on an A12GX - failure anyone?? ddgonzal 2003/7/16 6:37
             Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/16 12:32
               Re: PCV valve on an A12GX - failure anyone?? ang94541 2003/7/17 1:18
                 Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/21 2:11
                   Re: PCV valve on an A12GX - failure anyone?? ddgonzal 2003/7/21 4:42
                   Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/21 7:19
       Re: PCV valve on an A12GX - failure anyone?? Mazda626 2003/7/16 13:08
       Re: PCV valve on an A12GX - failure anyone?? Dodgeman 2003/7/16 14:28
         Re: PCV valve on an A12GX - failure anyone?? bobs1200 2003/7/16 17:02
           Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/16 23:03
             Re: PCV valve on an A12GX - failure anyone?? bobs1200 2003/7/17 0:37
               Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/17 1:16
       Re: PCV valve on an A12GX - failure anyone?? jaimecidpedro 2003/7/21 5:27
         Re: PCV valve on an A12GX - failure anyone?? rgrinder 2003/7/21 7:09
           Re: PCV valve on an A12GX - failure anyone?? jaimecidpedro 2003/7/22 0:03
             Re: PCV valve on an A12GX - failure anyone?? ddgonzal 2003/7/22 5:20
               Re: PCV valve on an A12GX - failure anyone?? rgrinder 2003/7/22 6:36
                 Re: PCV valve on an A12GX - failure anyone?? dattodude 2003/7/22 7:18
                   Re: PCV valve on an A12GX - failure anyone?? ang94541 2003/7/22 8:40
                     Re: PCV valve on an A12GX - failure anyone?? bobs1200 2003/7/23 1:09
                       Re: PCV valve on an A12GX - failure anyone?? jaimecidpedro 2003/7/24 2:59
                 Re: PCV valve on an A12GX - failure anyone?? jaimecidpedro 2003/7/22 20:43
