Re: A12 and A12A
From Stone Age somewhere in U.S.A.
the A12 has a 73 mm. bore, the A12A has a 76mm. bore.
they use the same crankshaft which has a 70 mm. stroke.
the A12A has a block that is similar to the A13, A14, and A15 with the distributor between cylinders 3 and 4. the A12 has the distributor by cylinder 1. the A12A also has the revised oiling system like the larger A series.
Posted on: 2003/7/18 6:43
Subject Poster Date
     A12 and A12A SpeedFreak 2003/7/18 0:34
       Re: A12 and A12A Brent 2003/7/18 1:55
         Re: A12 and A12A converted 2003/7/18 4:29
           Re: A12 and A12A Brent 2003/7/18 5:03
             Re: A12 and A12A SpeedFreak 2003/7/18 5:35
       Re: A12 and A12A rgrinder 2003/7/18 6:43
         Re: A12 and A12A 89mm 2003/7/18 7:12
           Re: A12 and A12A Brent 2003/7/18 22:53
             Re: A12 and A12A bobs1200 2003/7/19 1:12
               Re: A12 and A12A ddgonzal 2003/7/19 2:21
