Re: worn engines
If it's out of the car without a starter on it, there is NO way to tell if it's good or not. If it's out and can turn over with the starter, take a compression test.
If it's in the car and runs, you don't need a compression test. Instead do this:
- start it cold. Watch for blue-white smoke at the tailpipe. That is worn valve stems and seals.
- Warm it up and Rap the throttle two or three time up to about 3000-3500 rpm. No blue-white smoke should come the tailpipe. That's bad rings
- Pull the breather hose off the top of the engine cover, and pinch the PCV valve closed. No smoke at all -- not even a little -- should come out of the breather. That's bad rings. On a A-engine a liitle oil droplets might come out, but no smoke.
Black smoke is a carb problem or ignition problem. Not a big deal if you know that.
Posted on: 2003/8/12 21:16
Subject Poster Date
     worn engines sammy 2003/8/12 12:09
       Re: worn engines 2332owner 2003/8/12 12:18
       Re: worn engines mr_nismo4 2003/8/12 12:20
       Re: worn engines Mazda626 2003/8/12 12:21
         Re: worn engines kegs 2003/8/12 13:36
           Re: worn engines ddgonzal 2003/8/12 21:16
