Cylinder oiling/passage question
From Las Vegas USA
Ok I was looking at the H-production head as Nismo calls it and noticed a hole plugged that wasn't plugged on the GX head. The hole is on the manifold side in between #2 and # 3 combustion chambers. It is about 3 mm in diameter looks like an oil gallery. If I bolt the H-prod head on the GX block do you need top drill out this hole??? can the whole be drilled???
Tom
Posted on: 2003/8/19 18:47
Subject Poster Date
     Cylinder oiling/passage question Rallytwit 2003/8/19 18:47
       Re: Cylinder oiling/passage question AFRacer 2003/8/19 23:57
       Re: Cylinder oiling/passage question ddgonzal 2003/8/20 5:27
         Re: Cylinder oiling/passage question ddgonzal 2003/8/20 5:34
           Re: Cylinder oiling/passage question Rallytwit 2003/8/20 17:17
             Re: Cylinder oiling/passage question ddgonzal 2003/8/20 20:59
