Re: A12/A14 HYBRID! / OVER carburation...
From Wellington New Zealand
try this!
Overbore the A12, fit the A14 pistons to give 1270cc. You'll have to use the A14 gudgeons, and bore the little end out in the rod. I think you skim the top of the pistons too..hmmm???
Skim an oval port head down until you get around 10.5:1 compression. You can take heaps off these...
Plonk in a 280 degree cam, use 32mm chokes in the 42's and shout it headers and a decent exhaust.
It'll make around 100hp at 7000rpm and be the most fun you can have with your pants on!
People wont believe it's not an A14!
Posted on: 2003/8/21 22:18
Subject Poster Date
     A12/A14 HYBRID! / OVER carburation... toddat1200 2003/8/20 5:47
       Re: A12/A14 HYBRID! / OVER carburation... ddgonzal 2003/8/20 5:50
         Re: A12/A14 HYBRID! / OVER carburation... tsillay 2003/8/20 6:04
           Re: A12/A14 HYBRID! / OVER carburation... toddat1200 2003/8/20 7:55
             Re: A12/A14 HYBRID! / OVER carburation... 1200rallycar 2003/8/20 9:37
       Re: A12/A14 HYBRID! / OVER carburation... asunny 2003/8/20 13:07
         Re: A12/A14 HYBRID! / OVER carburation... 89mm 2003/8/21 0:15
           Re: A12/A14 HYBRID! / OVER carburation... 1200rallycar 2003/8/21 5:52
             Re: A12/A14 HYBRID! / OVER carburation... toddat1200 2003/8/21 6:14
               Re: A12/A14 HYBRID! / OVER carburation... 1200rallycar 2003/8/21 6:20
                 Re: A12/A14 HYBRID! / OVER carburation... Bullitt 2003/8/21 7:20
                   Re: A12/A14 HYBRID! / OVER carburation... no 2003/8/21 17:07
                     Re: A12/A14 HYBRID! / OVER carburation... tsillay 2003/8/21 22:18
       Re: A12/A14 HYBRID! / OVER carburation... ownerbuilt 2003/8/22 7:25
