Re: Minin tubs
Quite a regular
From Sunshine Coast
That was my plan dvldat but it is much easier to buy the mini tubs as there is someone out there that makes them. so all you have to do is cut the width to suit and weld them in. i have a mazdea bravo diff that wasn't shortened to fit and was just going to get a front wheel drive offset ti tuck it under the guards but the spring is the way. you need to have an engineer to submit drawings to the dept of transport to move your springs
Posted on: 2003/10/16 6:55
Subject Poster Date
     Mini tubs 1200CA 2003/10/15 2:26
       Re: Minin tubs DVLDAT 2003/10/15 5:45
         Re: Minin tubs 1200CA 2003/10/15 7:28
           Re: Minin tubs Dodgeman 2003/10/15 8:41
             Re: Minin tubs 1200rallycar 2003/10/15 12:56
               Re: Minin tubs DVLDAT 2003/10/15 13:08
               Re: Minin tubs stirlingmac 2003/10/15 22:30
                 Re: Minin tubs 1200CA 2003/10/15 23:31
                   Re: Minin tubs Dodgeman 2003/10/16 1:11
                     Re: Minin tubs 1200CA 2003/10/16 2:32
                       Re: Minin tubs MadTimo 2003/10/16 6:05
                         Re: Minin tubs DVLDAT 2003/10/16 6:44
                           Re: Minin tubs 1200CA 2003/10/16 6:55
                             Re: Minin tubs 1200rallycar 2003/10/16 9:41
                       Re: Minin tubs Dodgeman 2003/10/16 14:05
                 Re: Minin tubs phunkdoktaspok 2003/10/16 14:22
                   Re: Minin tubs MadTimo 2003/10/16 16:26
                     Re: Minin tubs datsterr 2003/10/16 23:37
                     Re: Minin tubs Dodgeman 2003/10/17 2:00
                       Re: Minin tubs L18_B110 2003/10/17 3:12
                         Re: Minin tubs CYA-18T 2003/10/17 3:23
                           Re: Minin tubs MadTimo 2003/10/17 12:18
                         Re: Minin tubs Dodgeman 2003/10/17 12:14
                         Re: Minin tubs ca18det_man 2003/10/17 12:47
                           Re: Minin tubs L18_B110 2003/10/20 0:49
                             Re: Minin tubs tsillay 2003/10/20 4:48
