HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!
From Auckland N.Z
Ive been having problems with my brakes for a long time now. The back drums are standard, the fronts are 255mm vented stanza disks and calipers and feeding these is a 180b master cylinder. My problem is the backs are almost always on. there not noticable when cold but after 2-5 mins its like towing a trailer and they really bind up in reverse. Ive checked the pads and they are correct and on ok, the hand brake is loosened off WHATS GOING ON!!!!!!! My thinking is it can be only two things, the slave cylinders are wrong (they look new, maby the guy before me got the wrong ones) or Ive set up the master cylinder wrong. Ive checked the shaft that conects to the brake peddle and its not under load. the lines are conected properly fronts go to the back and the backs to the front of the M/C. Im not sure if the fronts might be binding slightly but it feels as if the system is under pressure.
HELP!!! its really f*cking me off!
Cheers
Quinn
Posted on: 2003/10/22 11:35
Subject Poster Date
     HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! Quinn 2003/10/22 11:35
       Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! dattodude 2003/10/22 11:42
         Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! Quinn 2003/10/22 11:52
           Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! dattodude 2003/10/22 12:15
             Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! bobs1200 2003/10/23 0:58
               Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! Quinn 2003/10/23 2:26
                 Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! dattodude 2003/10/23 2:31
                 Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! bobs1200 2003/10/23 6:32
                   Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! dattodude 2003/10/23 7:42
                     Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! b310gx 2003/10/23 11:00
                       Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! Quinn 2003/10/23 11:28
                         Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! Dodgeman 2003/10/23 13:26
                           Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! dattodude 2003/10/23 13:30
                             Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! Dodgeman 2003/10/23 13:46
                               Re: HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP!!!HELP! dattodude 2003/10/23 13:57
