Re: Cheap and easy HP
Before you go looking at performance improvements, try going for the cheapest & best performance tricks. Give it a FULL tune up.
Check the compression. Thats always a good start. If your engine is down on compression then fitting twin carbs Etc. will not help much. Get the tappets correctly set, replace the points & maybee even the condenser. Set the dwell angle correctly & monitor it at about 1,000k, then 5,000 & 10,000k. Set the timing correctly & make sure that the vacuum can works correctly & does not leak. Replace ALL filters & fill with the correct grade of oil for the season & the use that you have for the vehicle. Make sure that the brakes are correctly adjusted & are NOT dragging. Make sure that the carb is correctly adjusted.
Depending on just how good or bad your car is tuned & serviced, you may find that this perks it up quite nicely. This is the baseline upon which you base further improvements, & this is abiut as low cost as you can get.
If the compression is down, then rectify the CAUSE of the problem. This usually involves the good old "ring & valve" job & is recomended before adding any performance improvements to a "used" engine.
Chris
Posted on: 2003/10/29 9:22
Subject Poster Date
     Cheap and easy HP 120yGuy 2003/10/29 5:11
       Re: Cheap and easy HP Peddler 2003/10/29 5:19
         Re: Cheap and easy HP kegs 2003/10/29 5:28
           Re: Cheap and easy HP 120yGuy 2003/10/29 5:34
             Re: Cheap and easy HP Peddler 2003/10/29 5:38
               Re: Cheap and easy HP 120yGuy 2003/10/29 5:46
                 Re: Cheap and easy HP Peddler 2003/10/29 5:59
                   Re: Cheap and easy HP 70coupe12 2003/10/29 7:31
                     Re: Cheap and easy HP ang94541 2003/10/29 7:51
       Re: Cheap and easy HP Dodgeman 2003/10/29 9:22
         Re: Cheap and easy HP Lobster 2003/10/29 10:41
           Re: Cheap and easy HP Dodgeman 2003/10/29 11:07
         Re: Cheap and easy HP kegs 2003/10/29 11:04
           Re: Cheap and easy HP Dodgeman 2003/10/29 11:26
       Re: Cheap and easy HP holeshot 2003/10/29 11:29
         Re: Cheap and easy HP Dodgeman 2003/10/29 11:38
           Re: Cheap and easy HP 120yGuy 2003/10/30 0:52
             Re: Cheap and easy HP dattodude 2003/10/30 1:11
               Re: Cheap and easy HP 120yGuy 2003/10/30 2:08
