Re: ar su's good for turbo charging through
Have a good look at the Post about Supercharging (there is 5 pages and nearly 100 posts), which is pretty comprehensive in all respects with a good mixture of engineering theory and practical experience.
If you want an opinion and I stress it is only that, blow through systems have a potential for pressure sealing problems that are likely to be the source of continuing headaches.
I reckon supercharging, either turbo or crankshaft driven coupled with EFI is the best bet by an order of magnitude.
Posted on: 2003/11/28 1:01
Subject Poster Date
     ar su's good for turbo charging through 310 2003/11/27 22:36
       Re: ar su's good for turbo charging through 89mm 2003/11/28 1:01
       Re: ar su's good for turbo charging through tens_and_twenties 2003/11/28 6:51
         Re: ar su's good for turbo charging through Dragongoose 2003/11/28 15:36
       Re: ar su's good for turbo charging through Dodgeman 2003/11/28 15:55
