Ball Joint taper
From Brisbane, Australia
Hello all,
"The Loaner" (B210) needs a new set of ball joints.
I was hoping to use a B310 balljoint to wind in some negative camber at the same time.
Any idea if the taper is the same between B210 and B310 balljoints?
This way I can use the existing steering arms.
Posted on: 2006/9/12 6:39
Subject Poster Date
     Ball Joint taper Cable_Tie 2006/9/12 6:39
       Re: Ball Joint taper LONGBROW 2006/9/12 19:09
         Re: Ball Joint taper Cable_Tie 2006/9/13 3:48
           Re: Ball Joint taper LONGBROW 2006/9/13 6:05
             Re: Ball Joint taper LONGBROW 2006/9/13 6:09
