FS: L20B with extras
Quite a regular
From Adelaide
Hey everyone I'm selling my L20b and all the gear that goes with it that is currently in my 120Y. I plan to put a rotary motor in it at a later date. Everything is still in the car and it is running and can be test driven.
The motor is out of a series 2 bluebird TRX, the head has been slightly ported and the block bore has been re-honed. Cam is standard as far as I can tell but I was told it was after market but I dont believe it to be and I dont know how to check. The Bluebird that the motor came from had 160,000km's on it and i was told it had been rebuilt at 150,000 and the head and bore work was done then. I have since done another 10,000km's on it.
It has pacemaker extractors which have been slightly shortened to fit in the 120Y engine bay and a 2 1/4 inch exhaust.
Intake is a Datrally manifold with twin 45mm side draught webers with 32mm chokes (also comes with set of 38mm chokes). Webers are currently tuned and balanced and make the best noise ever .
Clutch is an extreme racing clutch (purple framed) has only done 10,000km
Gear box is out of a 200b SSS. It is a 5 speed dog leg box with reverse where first should be and first where second normally is. This is the long gearbox by the way.
Im looking for about $2000 for the lot and may seperate depending on what is wanted.
If you want to know anything more please dont hesitate to ask. My best e mail is cfarrer@ellex.com or just post a reply.
BTW im located in Adelaide
Cheers guys and girls
Posted on: 2008/10/2 3:57
Subject Poster Date
     FS: L20B with extras 120Sly 2008/10/2 3:57
