Qld, Wts some 1200 and CA18 stuff
From Logan, QLD
Wishing to sell some of the gear thats filling up my garage at the moment
Firstly I have a ca18det, It is complete but in peices (how I bought it), The bottom end bearings look fine, It needs a sump gasket as I had previously remomved, I have a spare head gasket for it, It has no exhaust manifold but comes with a complete intake manifold, and 2 sets of cams both with tiny bit of surface rust on them (a normal det set and a normal de set(de set has longer duration exhaust profile) $200.
I also have a manual ca18det box $150.
Intercooler and bends for a 1200 ca18, Its a small intercooler from memory something like 500x190x62, with 2.5 inch outlets, the cold side matches right up to the throttle body on a stock ca18det inlet, the hot side would have only matched my conversion with a low front mounted gt2860rs, the rest is stainless elbows etc, the cooler was mounted infront of radiator but behind the grill with minimum obvoius radiator support cutting, as pictured. $100
Posted on: 2012/7/13 10:25
Edited by townie on 2012/7/13 11:18:55
Subject Poster Date
     Qld, Wts some 1200 and CA18 stuff townie 2012/7/13 10:25
       Re: Qld, Wts some 1200 and CA18 stuff ___1200ute 2012/7/13 11:50
       Re: Qld, Wts some 1200 and CA18 stuff townie 2012/7/13 12:47
       Re: Qld, Wts some 1200 and CA18 stuff townie 2012/7/13 13:55
       Re: Qld, Wts some 1200 and CA18 stuff townie 2012/7/17 8:10
       Re: Qld, Wts some 1200 and CA18 stuff DatsAndy 2012/7/17 9:23
