What is the fastest most accurate wa to check CC's in cyl head ?
From Seattle ,WA.
As stated in title - I need to figure out the volume of the cyl head chamber so I can determine compression, never done this before so not sure how. I figure someone here has done this numerous times and knows some tricks!
running Arias forged pistons, not sure how that affects the calculation as its certainly not flat which I assume changes how one computes the actual space between piston and head at TDC....
head gasket compressed at .041 - felpro Printoseal - steel sandwiched gasket, have original compressed one and new one for rebuild.
Thanks for the help!
Posted on: 2019/10/21 17:33
Subject Poster Date
     What is the fastest most accurate wa to check CC's in cyl head ? edp 2019/10/21 17:33
       Re: What is the fastest most accurate wa to check CC's in cyl head ? edp 2019/10/21 17:53
         Re: What is the fastest most accurate wa to check CC's in cyl head ? ddgonzal 2019/10/21 20:48
           Re: What is the fastest most accurate wa to check CC's in cyl head ? dvr1000 2019/10/21 23:24
             Re: What is the fastest most accurate wa to check CC's in cyl head ? L18_B110 2019/10/22 1:48
               Re: What is the fastest most accurate wa to check CC's in cyl head ? D 2019/10/22 3:51
                 Re: What is the fastest most accurate wa to check CC's in cyl head ? ddgonzal 2019/10/22 9:45
                   Re: What is the fastest most accurate wa to check CC's in cyl head ? ddgonzal 2019/10/22 10:05
                     Re: What is the fastest most accurate wa to check CC's in cyl head ? ddgonzal 2019/10/22 10:21
       Re: What is the fastest most accurate wa to check CC's in cyl head ? edp 2019/10/22 19:05
         Re: What is the fastest most accurate wa to check CC's in cyl head ? ddgonzal 2019/10/23 4:23
