Brake setup in 1200 ute
From Melbourne,Australia
Hi guys
Im just trying to work out what booster to use in my 1200 ute because with the ca in there there dosent look like theres much space avalible.I was thinking of using a 120y booster as they look pretty compact but how do you fit the clutch master next to it?
Posted on: 2004/4/16 8:35
Re: Brake setup in 1200 ute
From Christchurch. NZ
You could fit a remote booster, then it would fit anywhere. if you only need a little boost then some 4WD have tiny boosters on their clutches (about 100mm in Diameter)
Posted on: 2004/4/16 9:28
