electronic carb
From ipswich
the n13 pulsar single point injection operates much like a downdraft carby, which consists of a throtle body with an injector mounted in the midle. With a simple adaptor plate the throtle body will bolt up to a standard a series intake manifold. The wiring loom consists of a water temp sensor, oxygen sensor, manifold air pressure sensor, relay circuit for electric fuel pump and termo fan. This could be a succesive possibility for efi applications
Posted on: 2005/4/6 6:23
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Re: electronic carb
From Burbank, CA
yeah, the electronics from an E15/6i would work, just adapt the dizzy, add the O2 sensor and adapt the TBI and you'd have it pretty much.
it's TBI, but TBI is always better than a carb. While you're at it... maybe use a common/tunable OEM setup from another car, I don't know of any chips for an E16i.
Posted on: 2005/4/6 23:02
|||\ 81 KPB310 /|||
