E15 Turbo dizzy the same?
From Sydney
Afternoon Everybody,
Just a quick question, the distributors in the E15 turbo (N12 ET Turbo) are they the same as the natuarally aspirated version?
Reason being, i am unable to locate a Electronic dizzy out of a NA E15, but can i get a turbo one easily.
Thanks
Rhys
Posted on: 2005/7/21 4:08
Re: E15 Turbo dizzy the same?
From sydney australia
have you tried going to the holden section of the wreckers & checked in the la astra's,because they are rebadged pulsars,& use the same distributor.as for the turbo exa distributor,i
can't be sure,but i think they had a different
vaccum advance module,to allow for boost.
Posted on: 2005/7/21 7:11
Not too shy to talk
From Tasmania
No they will be diffrent as the E15T uses the ECU to control iginiton being EFI.
Posted on: 2005/7/21 7:43
