wheels
Quite a regular
From south brisbane
what type of alloy wheels are you guys using and what size are they
i tried to find some on the weekend but not much luck
Posted on: 2005/11/14 11:26
Re: wheels
From Stray-ya
depends on what your car is- there is only a handful of modern, large rims that will go on a stock datto 1200 because of the 114.3pcd stud spacing, but plenty of older stuff like jellybeans & hotwires..... just a matter of hunting the wreckers till you find them.
Posted on: 2005/11/15 1:33
Re: wheels
I happen to be running some old school enkei wheels (i think they are 92's), 14x6, I'd have to look for the offset, and I run 185-55-14 tires. The car is lowered 2" all around, I have the stock sway bar up front. I just upgraded the endlnks to help keep the fenders off the tires during hard conering. An Addco front bar is in the works. If you want pics let me know.
Posted on: 2005/11/15 4:46
Re: wheels
From Brisbane, Australia
Be careful what wheel you get. I had a heap of trouble because I got the wrong offset. I am now running 13x6 Globes with 185's. The backspace dimension is 112mm & it is perfect for my car (1200 sedan) but it will depend on what sort of struts & brakes you are running. If you want some wheels with the WRONG offset just let me know, i have a lovely set all newly powdercoated.
Posted on: 2005/11/15 13:15
Re: wheels
From Huntington Beach, California
Are you using the std struts and brakes? I'm looking for some rims, and was curious about backspacing and my 1200 is stock.
Posted on: 2005/11/15 23:10
Re: wheels
From Arlington, TX, USA
I do.
Posted on: 2005/11/16 1:29
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
Re: wheels
From Stray-ya
Duncan, maximum backspacing for a 120y strut is 114-116mm for a 13-14" rim, so you dont want to go more than about 112mm (will depend on tyres & rim width) I am pretty syre 1200's are the same as 120y. You get more backspace clearance with bigger rims due to the camber angle of the strut.
Stanza backspace is 128-130mm max so you can use rims with more offset if you do this upgrade
Edit: BTW i'm running 14x6 (185/60) +30 offset with stanza front. with 15"s you could go up to about +35 offset, or +38 to +40 if you are prepared to use spacers.
Posted on: 2005/11/16 2:03
Re: wheels
From Canberra, Australia
mine are 15's running 195/50 15 rubber.
Using stanza struts up the front... The wheels are very close to hitting the strut.
With the standard struts it would have needed a 10mm or more spacer on it. But there wouldn't have been any thread on the studs for the nuts to grip on.
Had to lip the guards and kind flaring the bottom bit out near the front.
Also had to put a spacer on the back to stop the wheels from rubbing on the inside.
Posted on: 2005/11/16 4:36
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: wheels
From mildura, victoria
im in the same boat im after a set of rims for my stock 1200 ute i dont now wat type they are all i have is a pic and i dont now how to get it in the thread? can anyone help?
Posted on: 2005/11/16 6:48
Re: wheels
From Brisbane Australia
I have gone really old school, wheels are original minilites 12" and I picked up some new 155 sr12 tyres.
If I could get all this in 13 inch with some low pro tyres that would be good but it looks the part and I am happy
cheers Ade
Posted on: 2005/11/16 7:46
(1) 2 3 4 5 »
