Browsing this Thread:
tailshaft
From Merimbula,NSW, Australia
just need to know in my stock 75 b210, im doing a auto 2 manual conversion and have got the 5 speed 56a gearbox from the datto sunny and im not sure if im gonna need a new tailshaft, i cant compare em for a while cause my car is 300km away with a busted radiator and head gasket thanks to my dear brother, any help well apreciated.
Posted on: 2006/4/1 15:20
Re: tailshaft
Yes, you're going to need a different tailshaft. See Propeller Shafts tech section article.
Posted on: 2006/4/2 1:53
Re: tailshaft
any idea what tailshaft ill need, i know the auto trans shaft is 15mm longer is it posible to shorten it or should i look for The 56 or 60 series trans shaft as im getting the 56 series gearbox?
Posted on: 2006/4/2 4:48
Re: tailshaft
You should get a 1975 B210 manual transmission driveshaft. 56 and 60 series boxes are the same length, so the shaft is the same. You might be able to use a B310 driveshaft, it all depends on *which diff* your car has.
Posted on: 2006/4/2 5:39
Re: tailshaft
does it matter if the driveshaft is from a 4 speed/5 speed manual transmission, is the driveshaft the same in both?
Posted on: 2006/4/2 7:41
Re: tailshaft
I recommend reading the 5-speed and Propeller Shaft articles. They will answer the question generally speaking.
Posted on: 2006/4/2 8:11
