What can cause the ignition timing to fluctuate?
From brisbane
The ignition timing on my CA18DET is all over the place at the moment. I have tried 2 different computers and 2 different crank angle sensors(condition unknown on both cas) with no improvement.
What can cause the timing to vary wildly?
Thanks Matty
Posted on: 2006/7/23 8:50
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: What can cause the ignition timing to fluctuate?
From Bunbury Western Australia
a faulty knock sensor, crook wiring between crank angle sensor and ECU or between Knock sensor and ECU are the next things I would look into
Posted on: 2006/7/23 13:42
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From brisbane
Thanks for the reply Blofly.
I have a couple of spare knock sensors so I'll swap one of them in this week and see if it helps.
Good tips about the wiring too.
Thanks again Matty
Posted on: 2006/7/23 20:53
From Tamworth, NSW
Check your points! the CA18 are always having probs with the points
yer that was a poor joke but any way........
Posted on: 2006/7/23 23:36
Project coupe:
Just drive it
