horn wiring
From southern sydney "the shire"
in a 120Y
i need some one to post up a pic of the 3 green wires (one is solid green, one has a yellow stripe and the other has a white strip)
these wires all go into a white female plug that plugs into a a brown thing that is mounted under the dash near the choke
can someone please post a pic of this because i need to know which wire goes where
Posted on: 2006/7/25 10:03
Re: horn wiring
someone please. i just need a pic of those 3 wires
Posted on: 2006/7/25 23:09
Re: horn wiring
The GW wire (power) goes in the center terminal
Like this:
._____
| ._. | GW
| | | |G
|_____|
GY
I think you'll find the GY wire goes up the column to the horn button. And that the Horns themselves have a G wire.
Be sure that the relay is bolted to the metal underdash so that it is grounded.
Posted on: 2006/7/26 5:49
Re: horn wiring
thanks heaps
Posted on: 2006/7/26 7:13
Re: horn wiring
is that diagram where the wires enter the white plug or is it from the other end
Posted on: 2006/7/26 7:25
Re: horn wiring
Ah, good question. That's at the white plug.
Posted on: 2006/7/27 4:11
