120y diff
From southern sydney "the shire"
what diff is in my 120y? its a late model 4 door sedan, 1976. is it a H145 or H155? do H165's only come out of utes?
Posted on: 2006/12/19 11:18
Re: 120y diff
From adelaide
id guess H150 for the aussie 120y, they say borgwarner on the bottom of housing, they have a rear cover
Posted on: 2006/12/19 12:08
1200 restoration project moving slower than it actually is
Re: 120y diff
From Geelong, Vic
it will be a BW if it has a removable cover at the back of the diff
and either a h150 or h145 if it doesnt
Posted on: 2006/12/20 6:22
Re: 120y diff
From Toowoomba Q Australia
So if its a removable cover bw. What size does that make it?
Posted on: 2006/12/21 1:31
Re: 120y diff
BW68
They are pretty strong - ment to be stronger than h165
Posted on: 2006/12/21 2:17
Re: 120y diff
From Geelong, Vic
does it say that on the diff, the BW68?
Posted on: 2006/12/21 2:34
Re: 120y diff
There will be a metal tag on one of the bolts that holds the cover on. I believe it tells you which type of borg warner, and also the ratio (makes life easy at the wreckers).
I recently put a bw68 from a corolla in my 1200 for the better ratio and wider track :)
Posted on: 2006/12/21 4:12
Re: 120y diff
From Geelong, Vic
was looking at a corolla diff just before, loks to be the same size as coronna and 200b BW diffs
Posted on: 2006/12/21 4:50
Re: 120y diff
See Rear Axle Swap
There are pictures there:
120Y 4-dr sedans and wagons were Australian assembled and had a Borg Warner diff (BW model 68). All were 3.89 ratio, although the 120Y wagon and panelvan might have had a different ratio.
Posted on: 2006/12/21 6:49
Re: 120y diff
From Adelaide, Australia
You say the BW KE?? corolla diff is a bolt in, will this bolt up to the BW 1200 tailshaft?
Also I measured my mates Ke30 Wagon, centre of leaf to centre of leaf and it was 10-15mm wider than a 1200. I was thinking the mounting lugs on the leafs are larger in diameter on a corolla and this should allow it to fit anyway. Can anyone verify this?
EDIT, I just read to wookie and it says that you need the 120y BW diff flange and 120y tailshaft, guess i can use the 1200 BW flange!
Posted on: 2006/12/21 7:11
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
